Dash lights won't come on and speedometer etc doens't work
Which fuse would be the one to check? Anything else that could be wrong? Just removed the center console and radio (put both back, and the radio is working fine).
Tried to change the headlight settings (on, off, auto etc) and turn the dash light intensity knob to no avail.
For the lights and speedo to fail does make me wonder if it is the connection to the instrument binacle.
There are 2 large connectors one on the left, one on the right, it maybe possible one of those has not clipped back properly. I do beleive the Rev had a nice video somewhere showing how to change dash bulbs which will be very useful for you to remove the wooden panel to get to the binacle and chack you plugs? Probably be my first port of call!
I am sure someone if not the Rev himself will point you in the direction of his vid?
BrentGardner
28
04-26-2024 03:08 AM
Tony K
03-26-2024 01:53 PM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
SingBlueSilver
08-27-2015 02:20 PM
