Dashboard- drivers side small black dome cover
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
Hello, does anyone know what the small ¾ inch black ½ round cover or dome on the drivers side of dashboard is for? It is missing and there seems to be some sort of light eye electronic piece that has been exposed. I assume the black cover is integrated for the piece to work properly. I think it disapearred down the front of dash by windshield. I assume I need new one. Does anyone know what this is called and/or where I can get a new plastic half round black dome cover for this? Thanks in advance
The formal name of the part is the SOLAR SENSOR. It is used by the AC system to measure to sun's heat load on the vehilce for more accurate temperature control.
I would agree that you need to replace the sensor as I don't believe it will work properly without the little dome in place.
-John
-John
Basically you hold down AUTO and RECIRCIULATE then switch on the ignition. Then hit AUTO again. The fault codes will cycle through on the display. The solar sensor fault code is '21'. If '0' is displayed, you have no codes.
vettegood (11-10-2011)
99xk8guy
06-05-2023 06:28 AM
