Dead Battery - Auxiliary Fuse Box
My battery is dead and I need to re charge it. Can't open the trunk. My key does not work when I insert it into the "XK8" emblem. I knew this prior but never had a chance to fix it or free it up. Can I jump the car from the terminals on the fuse box in the engine bay? Or, should I only use a trickle charge on that terminal?
Best practice would be to get the trunk open and then move the jumpers to the battery before engaging the starter.
There is a 250 amp fuse in the circuit leading to these terminals. That's probably enough with all but the deadest of batteries, all but the coldest of conditions. The car *can* be jump started from these terminals, but this should be a last resort; only if there's no way to get into the trunk.
If forced to go this way, as test_point said, best to leave the jumpers connected for a few minutes before engaging the starter.
Last edited by Dennis07; 12-26-2010 at 04:08 PM. Reason: Initial post had an error; I read the schematic wrong
![](http://my.execpc.com/B0/BE/pav/pav/XKRengine40c.jpg)
abonano
25
09-25-2015 10:43 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
