Default long term fuel trims
Did a hard reset after installing a new fuel rail pressure sensor and found the long term fuel trims defaulting to a steady 19.4 while the short terms are falling down to a 5 to 8 range after being high at first. I have only driven a short distance but the long term trims are not budging. How long should it take for them to come down to an acceptable level, assuming there are no issues. If they don't budge, then I guess I have either a vacuum leak or fuel supply issue.
Pistnbroke (04-22-2023)
long terms off idle aren’t changing because he didn’t fix anything
l don't think it does, that's why there is no change.
Thanks for the input. I did go fault finding which is why I replaced the fuel rail pressure regulator (originally had a P0193) only to have the fuel trims suddenly go up whereas they were pretty normal before replacing the fuel pressure sensor, as were the short terms. TBH, the car runs like a champ, starts right up and pulls like a train with no hesitation or stumbles now, as well as idles nicely. I tried to clear the ECU of stored fault codes as the car is running well so I thought it was just spewing up old stored fault codes. My guess is there's a vacuum leak somewhere. Will look into it further.
You are mis-quoting it. "DTC's and system adaptions" values, these refer to the options fitted to the vehicle such as power mirrors/seat memory/navigation/security etc.that must not be lost.
The fuel trims and other variable configurations/values are stil stored in volatile memory. I have a 2004 XKR and if I do a hard reset my fuel trims are also reset.
Interestingly if the battery is removed for a period of time the 6HP26 transmission adaptions are also reset.
If you still don't believe it and want to prove it, just do a hard reset and see what happens.
JagV8 (04-24-2023)
Hi Stumpy, my experience with a hard reset is just as you said. My fuel trims were reset to zero but jumped up to 19 after a few runs around the neighborhood. The other settings such as seat settings were not lost. I fixed the original problem (faulty fuel rail pressure sensor) only to be faced with some lean codes (both banks). Time for more troubleshooting!
ECM's, nothing to do with seats and mirrors etc.
OK you carry on believing the training manual and ignore the people who have actual experience of these sytems and are trying to inform others of what actually happens. END
G.M. Webster
02-20-2023 09:33 AM
