DESPERATE! Need help fast! Car stalling.
Old 07-29-2010 | 04:42 PM
Fraser Mitchell's Avatar
The recent crash at London Heathrow AIrport was caused by frozen water in the fuel. It is very difficult to remove the water in fuel. For cars, it accumulates at the bottom of the tank, and then normally get sucked into the fuel injection system and then into the cylinders with the effects described. It is not usually a problem here in the UK, but if there are a lot of filling stations that don't sell much petrol, it can collect in the storage tanks and get transferred to cars. I believe modern fuel filters will hold on to small amounts, hence the need to replace them.
My first Jaguar, a Mark 2, had a glass bowl filter. You could immediately see accumulated water, as it collected at the bottom of the bowl.
  #42
Old 07-30-2010 | 01:06 AM
Reverend Sam's Avatar
Yep, I'm a pilot, and part of the pre-flight inspection is to use a little cup to drain fuel from several spots on the airplane and inspect it for water. Water accumulation can be pretty bad on small planes that don't get flown very often. The fuel tanks are vented and as the plane heats up in the sun then cools down at night air gets sucked into the tank. The water in the air condenses on the cool metal parts at night, then drips into the fuel. It doesn't take long for tanks on a small Cessna to accumulate a few teaspoons of water, which is enough to kill the engine in flight.
  #43
Old 08-08-2010 | 09:22 PM
Gus's Avatar
Gus
Originally Posted by Gus
Sam I did not use the grease I used the spray http://www.crcindustries.com/auto/co...x?PN=05105&S=N . When I used it I removed and installed the plug several times to ensure a good contact. Good Luck and make it home safe!
Just an update on my stalling car. After the quick on the road cleaning of the electrical contacts at the TB, I drove the car an additional 700mi and had no additional problem.
BrentGardner
28
04-26-2024 04:08 AM
Isoruku
06-19-2020 01:54 PM
aquifer
08-29-2015 05:54 PM
SingBlueSilver
08-27-2015 03:20 PM
Vector
US Lower Atlantic
08-26-2015 06:36 AM
Quick Reply: DESPERATE! Need help fast! Car stalling.
