Dexron III in the ZF 5HP-24 Transmission???
I just bought a 2000 XK8 a month or so ago. I have yet to get it on the road, (since it did not start). Got it started, finally - after replacing the Starter, replacing the Crank Position Sensor (had set P0335 code), having the Fuel Injectors cleaned and serviced and oiling the cylinders) and am doing all the necessary checks before putting it on the road. Well, guess what I found that the prior owner had done? The Transmission shows evidence of being out of the Jag at some time and there is RED fluid in it (most likely Dexron III), not the correct Esso Fluid. GREAT!!! Now the question is - How do I get all this wrong fluid out so I can refill it with the correct Esso Fluid? Does the torque converter have a drain plug? The RED Fluid still is Red and not burned. So maybe the prior owner never got to drive it with this wrong fluid in it (he had said that he had just had the transmission serviced...IDIOT!). Is the transmission ruined because of this or can the fluid be changed out and refilled with the correct fluid? Or do I start looking for a replacement for it?
There are several ATF manufacturers that claim to meet the LT71141 specification that may have the more traditional red color. I do not believe that Dextron III is one of them but you seem to be guessing that is what was used. Many folks use the alternative fluids because they are 25%, perhaps 90% less than the ESSO brand.
Can you find out where the transmission was serviced?
The 5HP24 did not have a drain on the torque converter.
To completely flush your trans and transcooler you need to find a shop which has a trans flush machine.
There are two types of flush machines. The first has a pump, which forces the ATF through your entire system. The second uses your transmission's pump to drawn clean fluid into the trans thereby pushing old fluid out.
One of the lines between your trans and the transcooler (radiator) is disconnected and the trans flush is inserted in between. The capacity of your transmission, including lines and cooler, is noted. Then that amount of old fluid is pumped out into a reservoir which means an equal amount of new fluid was pumped into the system.
Obviously the mechanic checks the side port of the trans, in gear, proper temp. etc., to insure the fluid level is correct ot factory spec.
Trying to drain from a non-running [non-pumping] engine only results in about half to 2/3 of the fluid being exchanged. There is a substantial amount of fluid left in the torque converter, lines, etc. The balance of the old fluid immediately mixes with the new fluid.
Received 2,192 Likes
Thank you for everyone's input! it is putting me more at ease that the Red Fluid may not be as big an issue as I thought. I have yet to try driving the Jag... I get no Warnings or Red Lights on the dash. Only DTC's the engine has set are P1316 and P0307 - both related to a misfire... no doubt, since this had to burn the oil in the cylinder oiling to get the compression back up to run it. Runs great, with a slight occassional miss. I will be changing plugs shortly to see if codes do not repeat. On to ther next issue...
Using the incorrect ATF is not synonymous with drinking Draino. Given the fact that uncounted miles were driven before you purchased the car, IMO driving around the block to test something is not going to be an issue.
ATFs are all slightly different and your trans is designed to use those fluids specified by industry standards. Notwithstanding what was just said, having poured in a quart of incorrect fluid will not cause the trans to burn up or explode. As you correctly surmise, it would be in the best interests of your trans to insure the correct fluid is used. Consequently before you begin driving the car on a regular basis, get the fluid flushed.
Cheers, Jarle
Capacity
There is a great manual for the 5HP transmission her eon the forum that will probably give you the capacity.
From a practical perspective, I just had the pan dropped and a new filter installed ($<$20 @ Rock Auto) and used about 6 1/2 quarts of Mobil 1 Synthetic (it was red) to complete the job. ($7.99/Qt). My indy shop charged me $107 labor.
Good luck with your car!
