Differential fluid change
Here is a way:
https://www.jaguarforums.com/forum/x...iff-oil-71492/
You could also take of the rear strut brace (not sure the naming, so attached the picture), that way you have easier access to take out the filling plug, and syphon out/refill the oil.
You can use Castrol Syntrax Longlife for instance.
aholbro1
08-05-2021 05:02 AM
Wes Steenrod
09-06-2015 06:52 PM
change, changing, checking, differenial, differentail, differential, fill, fluid, jaguar, muck, oil, rear, recommended, xk8, xkr
