Direct Replacement parts - Ford or Lincoln catalytic converters?
Does anyone know if any of the later model Fords or Lincolns catalytic converters are direct replacements for Jaguars, specifically the right bank, passanger side, of a 2000 XK8?
Thanks.
Thanks.
Last edited by GGG; 07-11-2013 at 06:17 PM. Reason: edit thread title to add detail
I'm going to doubt that any of the Ford/Lincoln parts would work here since it is fairly tight for space, but before you consider OEM Jaguar, try Nameless Performance. You can get some very nice units that flow better than OEM and for less money. I've heard the wait time can be long though.
My personal experience with replacing OEM cats with aftermarket cats is limited to General Motors LS engines, which are larger in displacement than any current Jag motor. Found that a much smaller aftermarket cat fit just fine and performed well for 90K miles.
With that experience I think you could probably fit a Ford/Lincoln cat from their "Jaguar-like" motors. But you will have to confirm fit from the general outside dimensions. This is critical. It probably will not be a "drop-in" fit. That's too much to hope for. I think then that a competent exhaust shop could work up a fitment, cutting in a new cat to your existing inlet/outlet connections..
Nameless Performance's cats are simply aftermarket cats with mounting connections to fit particular Jaguars. In my judgement, they are not exotic.
My guess is that Ford/Lincoln or quality (note "quality") aftermarket cats will pass any sniff test; but, beware of California which prohibits any change to OEM.
BrentGardner
28
04-26-2024 03:08 AM
