Disconnecting Battery
I found corrosion on my negative battery cable. I want to disconnect and clean thoroughly. Is there anything I should know before doing this? Do the radios have theft codes? Will anything have to be manually reset after the disconnect?
I have a Silver/Black 2002 xkr. Thanks.
Received 6,313 Likes
If you've got terminal corrosion issues, it's worth checking the battery age as these vehicles are very sensitive to battery condition.
With the original factory fitted Varta batteries, the manufacturing date is stamped on the top of one of the terminals. Code is MM/YY for month and year. Anything over five years old is on borrowed time.
Hey there:
Just in case you dont know there is a proper sequence. When disconnecting battery take off the negative first, then take off positive. When connecting connect positive first then negative. If you slip or touch the car body when removing the positive if your negative is disconnected you will not make a circuit and short the battery ( not nice ). Thats if you are not using a rubberized wrench.
Howard
Howard
Thanks all. The negative battery terminal crumbled when I tried to take the nut off. Of course the dealership is closed already so I will have to wait until Monday. The window presets....Is that reset for the rear quarter windows to go down when the top is activated? I guess I better go search for that forum now. Thanks for the heads up. Today I was able to find and replace the blown fuse so I can charge my phone. I replaced the blown dash bulbs (should have waited and installed LED's) and completed battery maintenance. Battery is stamped 12-22-06. Sounds like it's time to replace it and prevent a break-down. anyone know the best source for a battery?
Suggestions:
Autozone for the battery. Good price, good quality.
Everything I had read said my car would not ask for a radio code after the battery swap. Seems nobody told the car about this. I got the needed code from the local dealer, but it would be good to do this step before the battery swap just in case.
If for any reason you decide to remove the battery (or disconnect the negative) and leave your vehicle with the trunk closed, it would be a good idea to check that your key will open the trunk upon your return~have read elsewhere on this forum the key locks sometimes corrode and will not function due to lack of use! Fortunately my lock WAS working just fine when this happened to me!
Dennis07...I wish I had read your response before disconnecting the battery as my car decided it wants a radio code now also. This sucks and blows at the same time if that were physically possible! Guess Im headed to the dealer Tuesday for the code. No music for the next two days. I got my negative cable and battery from Napa so at least I feel secure about that.
Disconnecting the battery loses the presets and it takes a whole lot longer to reset these than it does to punch in a four digit code.
Knowledge - it looks as if there is a heap of things to do once you reconnect. With the help of Graham + some others I'm currently trying to compile a definitive list which I'll post as Things to do after a Battery Reconnect
Maybe a DemiGod will make it a sticky since I believe it is new information not covered in the forum.
There's bits all over the place but the current stuff is here https://www.jaguarforums.com/forum/x...gh-idle-74050/
