Do door modules have to be programmed?
2catlimit (07-02-2016)
The VCATS (Vehicle Configuration and Test System) label is specific to each individual vehicle and lists the VIN of the vehicle together with the Part Numbers of the CM's (Control Modules) originally fitted to the vehicle during manufacture.
For the Door Control Module, the VCATS label will show something like LJA2120AJ/002 where the first nine digits is the Part Number and the last numbers are the market identifier.
For the 4.0 litre cars, there's a Part Number change at VIN A21853. There's a further Part Number change for the 4.2 litre cars.
This means the VCATS numbers for Door Control Modules will not be all the same on 1996-2006 XK8/XKR's. Those with the same Part Number should be interchangeable without reprogramming. It would be interesting to know if any DCM can be programmed to any 1996-2006 vehicle.
A statement like taken must be taken in context or it can lead to false conclusions. Given your issue with the passenger door, presumably your question to them and their response related only to DCM (Door Control Module)?
Anyone with a good eye (a magnifier helps) can visually inspect a module for obvious defects such as bad solder joints, broken copper traces, leaking capacitors or obviously burnt or physically damaged components. Sometimes you can get lucky and the electronic defect is visible.
What is your problem with it? How did you diagnose the module is bad?
Door module was plug and play. My tip for the R&R. It was a little difficult to get unplugged. When I was re-installing the module, I unseated the two white plastic fittings that hold the wiring in place. They are easy to see, just look for two white pieces poking out of the door panel near the speaker.
I purchased the module from European Automotive Group out of Moultrie, Ga. They are very knowledgeable regarding specific issues with Jaguars. I spoke with Davey and he went above and beyond. The asking price was $150.00 plus $12.00 for next day shipping, right in the middle price range of what I had found. They also offer 90 day warranty compared to the standard 30 day. He agreed to $125.00 plus shipping and in addition to the discount he sent me FREE OF CHARGE the small front door speaker and cover I needed. I placed the order at 3:30 pm and it was on my door step the next day by 2:00 pm. Here's their contact info: 800-761-3876 europeanautomotivegroup.com
Looks like a great used part source...thanks for sharing.
Hi Guys and Girls
I searched the forum by part number so thought it best to add to this string for relevents
I have found that my drivers door window wouldn't lift when the door was closed.
I have done all the battery check thing and programming but the window would still not lift when the door was closed.
I have been in the doors today installing the new polk speakers so took the liberty to swap the door control modules over.
I reprogrammed them and low and behold the lift issue migrated to the passenger door and the drivers door is ok.
I did split the module but my belief is that the electronics are not getting the door closed signal.
There are no evident cracks or dry joints visible on the pcb or connector terminations.
What I would like to know is that my module numbers are LJA2120AG/XXX. I have found a LJA2120AJ/XXX. will this fit or do I need to find a G coded unit?
Thanks in advance
Wayne
Thanks in advance
Wayne
99xk8guy
06-05-2023 06:28 AM
RaceDiagnostics
09-13-2015 02:22 AM
al_roethlisberger
09-07-2015 10:53 PM
