Do I need to buy the gasket?
here is the 8 green replacement gaskets that go into bottom side of the plenum. Jag does not sell these, this is what I got per suggestion from Jagbits.
RANGE ROVER SPORT LR3 Part# 4526549 | eBay
Dude that sentence does NOT suggest you told me to go to ebay!! I got that part# per you all, I just got it off ebay.
Post #34 is where I suggested them. Again not saying you told me to go to Ebay.
https://www.jaguarforums.com/forum/x...-127905/page2/
Damn I spent a pretty penny with you all, I feel I am getting slapped on the hand here.
We gave you the Jaguar part number correct and you found it on Ebay? Ok I misunderstood I would have to read it again, I thought it said we gave you a Rover part number and directed you to Ebay so I thought you had Jagbits confused with someone else. No big deal either way I just wanted to make sure I understood it correctly...
as far as I know you HAVE to remove the black plenum. You can not remove the TWO valley hoses without doing so. To remove the plenum you must remove the TB. Unless someone can say otherwise, that was what my research told me to do so I did.
How many miles are on your car? Just replacing the valley hoses for preventive maint???
When you do the Valley hoses it adds much more work since you have to remove the TB and TB Elbow, which is more gaskets, then you may break the brake boost line that is a black plastic tube that has silver heat sheathing over it that comes out of pass strut tower directly into the TB/Elbow That tube passes through the TB where is is getting vacuum from. Well in the TB there is a oring that is ganna be dried up and shot, you will need to by a kit to redo that stuff. I the valley hose job is not as easy as you think.
The pass side valley hose connects to a tube, same tube the pass side octopus hose connects to, well on that tube, there is ANOTHER smaller hose that goes to the EGR, when I got down to that hose it was all BLOATED, leaking looking for a place to happen. So I replaced it.
giandanielxk8 (01-27-2015)
Please note that there is a difference between the early and later XK8. When ordering parts be very mindful or taking advise.
BRGJAG in good faith is trying to give you the right direction, but his car is the later model and may have you looking for things that are not there or different.
If you have done the octopus hose, you are going to have no problem with this.
Do a good write up and give all a heads up on what you did, seems we all have a different problem on every task.
Wayne
Wayne
#28
#30
Just a heads up in case you haven't already realised - you will need a fuel disconnect tool for the fuel rail junction. Removing the inlet manifold is not difficult - just time consuming. Work methodically, take photographs as you disassemble and mark all fasteners to avoid confusion when putting everything back together. As said previously it's good practice to never re use gaskets. Worst bit of this job that I recall is the bolts on the side of the inlet elbow(the one the TB bolts to) - they are awkward but not impossible. Torque everything when rebuilding - you're fastening into alloy. Any problems just shout.
Dimitrigregorio
17
09-05-2019 03:47 AM
Bob Gelston
09-14-2015 11:08 PM
1964Daimler
09-09-2015 11:20 AM
