Do I need to lube o'rings on injectors before installing?
I got my fuel rails and injectors back from Injector RX, they capped my pulsation dampeners and cleaned up my injectors and put all new o'rings on them. Do I need to lube the o'rings at all and if so with what before I pop them back in the rail and into the intake???
well reading it here and Googled it, I used a motor oil. I guess we will see it it leaks. I have already mounted them into the rails and clipped them in. Tommorrow or this weekend I will button it all back up and hope the hell all the work I have done to the car (my other threads) that she will fire up and run.
Here you go:
Injector_Installation.pdf
If you will be working on the car regularly JTIS is a handy tool to have:
https://www.jaguarforums.com/forum/g...rchives-65926/
aholbro1
08-05-2021 06:02 AM
