Do Our Cars "Learn"?
This is a serious question! I've had my XKR for about 6 months now. I know the previous owner was an "easy" driver, and I have been too as I got used to the power, handling, braking, etc., but more recently, I have been driving "harder" - faster, more downshift passing, higher speeds, faster turns, quicker stops, etc. (also, spring is here and the weather is nicer, roads dryer, etc.)
It seems to me that as I have pushed the car more, it has responded more - firmer, better directionality in steering, more secure ride, etc - or is it just my imagination?
As I read all the posts about all the computers onboard - I wonder - is it learning my driving habits, or am I just getting used to it? Thanks, DaleD99
I believe only the transmission has some learning ability. Oh, the engine has fuel trim and likely some sort of anti-knock learning too, but you won't feel any of that.
Everything else is probably just you and the XKR forming a closer and more communicative relationship. Nothing wrong with that!
It is just the computer activated performance adjustments that are programmed in the XKR systems. That is a big difference between the XK8 and the XKR. The CATS system on the XKR (Computer Active Technology Suspension) doing what it is supposed to do is what you are describing.
That was the biggest thing we noticed when we were in the process of buying our car and it came down to an XK8 and the XKR, the handling and road feel was significantly different and totally adjusted and changed noticeably (all to the good) when pushed at speed in the corners.
Sounds like your car is running as it should!
Cheers,
Mark
Nati
05-16-2020 08:30 AM
SingBlueSilver
08-27-2015 02:20 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
