Does anyone have a ABS rotor nut socket tool?
Old 08-16-2013 | 05:47 PM
Windycityx's Avatar
Default Does anyone have a ABS rotor nut socket tool?
For borrow or for rent?
Or the off chance if you know anyone in the Chicago area who has one?
Thanks!
Old 08-16-2013 | 07:05 PM
Beav's Avatar
I read in a post in the forums that someone used a 2 or 2½" 12 point socket with success.
WhiteXKR (08-16-2013)
Old 08-16-2013 | 07:07 PM
avt007's Avatar
a 12 point 2 inch socket works also. I used an impact gun. Beware you run the risk of damaging the nut if you're not careful.
Old 08-16-2013 | 09:40 PM
Windycityx's Avatar
Is that 100% ok and there won't be any damage if done carefully?
Old 08-16-2013 | 10:30 PM
avt007's Avatar
It worked for me taking it off with an impact gun, and putting it on with a big torque wrench. The biggest problem is getting the bearing. It will require a heavy-duty press.
Old 08-16-2013 | 11:23 PM
bsprowls's Avatar
I posted in this thread a while back about my success using the 2" 12 pt socket:
https://www.jaguarforums.com/forum/x...ow-easy-81555/
Worked perfectly for me.
aholbro1
08-05-2021 06:02 AM
Poet
10-06-2015 10:40 PM
wannajag
09-22-2015 09:29 PM
mrplow58
09-15-2015 10:58 PM
iownme
09-11-2015 03:57 AM
Quick Reply: Does anyone have a ABS rotor nut socket tool?
