Does this engine look healthy?
Last week when I did my valve cover gaskets, I took a picture of my cams and valvetrain. Just by looking at these pictures, what do you guess the mileage is on this engine? Does it look to have been well maintained or does it look worn? The attached pictures are of both banks.
I am not sure that anyone could really guess mileage based on visible inspection like that.
Can’t say anything about the cam bearings with the caps in but there appears to be no significant wear on the cam lobes so your valve train is heathy. There is appears to be no build up of oil sludge anywhere in there so the oil has likely been changed regularly and with decent quality. Chains look fine, with no obvious wear and the slipper that is visible is not missing any pieces.
It does appear there is a cat hair on the right side intake cam, which might be a problem. Strongly suggest you remove all felines from the oiling system before restarting the car, they are known to make noise for the first few minutes of running until they cook off.
The following 3 users liked this post by ccfulton:
Can’t say anything about the cam bearings with the caps in but there appears to be no significant wear on the cam lobes so your valve train is healthy. There is appears to be no buildup of oil sludge anywhere in there so the oil has likely been changed regularly and with decent quality. Chains look fine, with no obvious wear and the slipper that is visible is not missing any pieces.
The following 2 users liked this post by giandanielxk8:
DavidYau (02-27-2021),
MikeAlford (02-27-2021)
The following 2 users liked this post by Reverend Sam:
giandanielxk8 (03-01-2021),
sklimii (03-02-2021)
Rev Sam! You're back! Have you returned to Jaguar ownership?
It's nice knowing that, despite the lack of maintenance records of my car before my tenure, it was well taken care of. I have found other instances where I am doing a job and can clearly see that someone has been there before. In fact, there are things that I have done preventatively only to find out midway through that it has already been taken care of. However, might as well redo since I'm already there.
sunchip
08-28-2023 09:21 PM
