Does the R in XKR stand for RESTRICTED? (knock sensor knowledge needed)
Had the RP light come on, and eventually the engine light. Pulled codes and found P0333. Reset it once as I read that it could be intermittent from a bad rain / getting wet. Also wanted to see if it would re-occur (and here I am!)
I searched High & Low not only on Jag Forums, and haven’t found much , except for Gus’ right up on how he ended up at the Knock Sensor problem (Saddens my heart).
I found somewhere that the supercharger will need to be removed.
If anyone has any pictures / explanations / available links / advice I would really REALLY appreciate it.
Even if I knew where to find it I could at least inspect it / clean it. I did see the pictures written up in the XJ8 section on the 4.0 NA, and have yet to compare.
Are the 2 engines similar in where the knock sensor is located?
AGAIN, any help is HUGELY appreciated !!
BrentGardner
28
04-26-2024 03:08 AM
FS[NorthEast]: Jaguar XKR Wheels for Sale
Griffbritgreen
07-27-2016 05:43 AM
FS[Central US]: 1999 XJ8 Parts or project car for sale Lawrence, KS
casepie
08-30-2015 09:49 PM
Terrance Williams
08-26-2015 11:50 AM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
