Does supercharger really require spark plug replacement every 30K miles?
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
If in doubt you could check your plugs to see how they look, that should give some indication.
I use also a heat range colder plugs (6) on my car, and my plugs look very good, so guess it will be alright.
You could also keep your plugs and add the twin-screw, that way you will have the right heat range![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
And... do them one at a time. That way you don't forget which wire goes to which plug. Many years ago I made the mistake of pulling off all of the wires and replacing all of the plugs at once (on a different car). That was before the internet, and figuring out which wire went where took forever since I couldn't drive to the auto shop or library to look it up. Some lessons are never forgotten.
Just pulled the work sheet from the dealer. Fitted the following plugs: C2A 1535
to my 2001 XKR 4.0L at 68,000 miles. Only done 73,000 so no need to change. Looking on the web these plugs are Iridium Spark Plug - C2A1535 - Genuine Jaguar at www.rimmerbros.co.uk.
They had previously fitted AJ8 4575 plugs at 43,000 (so a 30K interval) - these also show up as Iridium so I am guessing likely same plugs with updated part numbers
I presume no great difference with NGK or Denso. Likely made by them anyway and rebadged.
Steve
Steve
xjrjag
10-27-2021 11:48 PM
X_Type_South_Africa
12-09-2015 05:37 PM
