Door adjustment
Old 06-05-2015, 01:53 PM
Volbrewer's Avatar
Default Door adjustment
I need to raise the rear of the driver's door about 3/8" to get it properly aligned, so I need to get to the hinges to re-position them a bit. Any way to do it without removing the fender?
Old 06-05-2015, 03:53 PM
WhiteXKR's Avatar
Received 2,984 Likes on 2,124 Posts
Is the misalignment also at the hinged end of the door, or does is grow worse as you move toward the latch? If it is the latter, door sag is common on these car due the long, heavy door.
It sounds crude, but door sag, in most cases it can be corrected by opening the door, grabbing the end with two hands and simply heaving the door upwards.
Old 06-05-2015, 04:57 PM
Volbrewer's Avatar
Guh-wow! That do sound crude, but I have to say I've been really stressing looking at what it might take to get to those blasted hinges. I figured one or more generously proportioned PO's had been using the door as a crutch to get in and out, but long door/sagging makes sense. I'll gladly give the old heave-ho a try. Thanks!
Old 06-05-2015, 09:05 PM
platinummaker's Avatar
Had the same with my 98 very. Went to the body shop that does all of the Jag dealership work, and they put a handle type device on the door and lifted it up. It's been good for over 5 years now.
Old 06-05-2015, 09:15 PM
HokieJag's Avatar
Gave my sagging passenger-side door a heave last year - it took 2 or 3 tries to get it right, but it did the trick.
Old 06-05-2015, 11:47 PM
scottatl's Avatar
i actually took a jack with a wood block and pushed it back up, worked like a charm.
Old 06-06-2015, 08:44 PM
RCSign's Avatar
As written by Scott
I've never had the problem with the Jag.
When we owned our collision repair center back in the 70 & 80's that was one of the easiest adjustments.
99xk8guy
06-05-2023 06:28 AM
Samheath100
09-17-2015 10:03 AM
RaceDiagnostics
09-13-2015 02:22 AM
jagent
09-12-2015 09:10 AM
TexasCat
09-08-2015 04:36 AM
Quick Reply: Door adjustment
