Door handle gaskets
Once again, I'm appalled at parts prices. Like most of us my door handle gaskets are crumbling at the rolled, exposed edge. No problem, a couple beers and a few tools and I'll be done. $99??!? For two gaskets? Apparently someone has an unhealthy habit they want me to support.
After about thirty-two seconds of consideration I came to the conclusion that the 'real' sealing portion of the gasket occurs underneath the handle and that the crumbling, rolled edge is purely cosmetic. So I grabbed a razor blade and trimmed the remaining rolled edge away. Simple. And cheap. And just to help out, I'm forwarding the razor blade to the guys that own the parts store. Just to help them reduce the cost of their habit.
PKWise (04-11-2022)
Sam, I think you may be right, not a dealer item, but Jagbits sells them: http://www.jagbits.com/mm5/merchant....LM12035-GASKET
That sounds complicated. I'm going to buy a tube of black RTV today. This evening I'm going to pop off the door card, loosen the handle mechanism, and completely remove the gasket. Then I'll squeeze a tiny bit of RTV on the under the mechanism, tighten it down, and let the RTV squeeze out from behind it. Then I'll smooth the RTV with my finger, leaving a thin bead between the door and the handle. I'll post a picture when I'm done. I don't think something this simple warrants a video.
my gasket cracked, peeled up, and before I could do anything about it, a piece of it came off...now I'm considering my options. Hmmm...
Anyone do something that turned out looking good, or replaced their gasket by going the route of the replacement? If its easy, I'm going to do $35 Welsh Enterprise part route.
I've done this many times, making gaskets for cars that you cannot get. You can buy sheet rubber of the internet or local suppliers I have a large sheet in my shop just for this. it's about 3/32 of an inch thick,cuts with scissors or a X-Acto knife. With a little patience you can make new gaskets and they are cheap. They won't have the bead but how many people will notice. I think It'll look more presentable than trying to use RV Sealant and trying to make a presentable bead. Some people will be able to, but many would have a rough time making it look good, I know I would
I just looked as you mention we sell them. They are sold as a pair for $79.00. Not worth the time to make do and still will not look as good as new ones in my opinion. I needed one on my car a while back and you do have to cut the retainer on the back (rather obvious as to where) as they originally come built onto the handle mechanism. This way you can just undo the handle from the door and keep the linkages hooked up and snake the seal into place.
12035 GASKETS don't fit anyway. Here are 2 pics for proof. Don't waste your money.
Does anyone have another solution to better gaskets? Different part number, different source? Mine are too damaged to just trim with a blade.
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20220410_123150_4b69ac07d73d24e42c9ee869d2180cb0a4f99b83.jpg)
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20220410_123527_0fca018678832e8035263833bb80c8742436d3de.jpg)
I got the gaskets from Welsh and installed them. It was not a hard job. The harder part is pulling the door card. They have been on for a couple years and still look new. I also was able to find the radio antenna gasket from them, very rare find. When this gasket fails, you get water in the trunk.
al_roethlisberger
02-28-2017 02:19 PM
