Door Handle Rubber Gasket
Old 07-11-2010, 08:46 AM
jpm3's Avatar
Default Door Handle Rubber Gasket
My 2000 XK8 has suffered the effects of the sun. Both door handle rubber gaskets have deteriorated and parts of them have come off. I called the dealership and was told that the gasket can not be purchased without the entire door handle. The door handle is $761 EACH!!!! I chose not to spend $1522 for such a minor cosmetic problem. Has anyone tried to repair their broken door handle gaskets using Permatex? I'll take some pictures and post them later today.
Old 07-11-2010, 09:20 AM
itspec60's Avatar
You will need to purchase JLM-12035/kit. I found it at Coventrywest. The gaskets come in a kit (as the name implies) both right and left door, about $80. You need to remove the door handles and install the new gaskets. I posted a repair on this subject called "drivers door, outside handle removal"
The following 2 users liked this post by itspec60:
Dan R (11-21-2010), rickjensen (11-09-2012)
Old 07-11-2010, 11:41 AM
jpm3's Avatar
Thanks. Once again, bad and very expensive information from the dealer.
Old 07-11-2010, 12:37 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
The dealer doesn't have the rubber trim/weathersealing separately, its an aftermarket item. A good niche too. Dealer parts don't deserve the bashing this time.
Old 07-11-2010, 12:41 PM
viscoussquirrel's Avatar
You know I'm glad you posted this, A friend of mine was was knocking the Jag for it's peeling gaskets the other day, and I had not yet begun to research a solution. I love it when an answer to a question I haven't asked lands in my lap. Thanks!!
Old 07-11-2010, 01:06 PM
H20boy's Avatar
Itspec did a good job with the instructions, but if someone wants to document the removal/reinstall with some visual aids (you got it...pics!) then add it here, or his other thread that he started. <- and FAQ'd for future use
Old 07-11-2010, 11:46 PM
hm1's Avatar
hm1
hm1 is offline
Is there another source for these rubber parts?
Old 07-12-2010, 10:45 AM
H20boy's Avatar
not that we can find on the internet. I don't think coventry will reveal any either.
Old 07-12-2010, 11:12 AM
MrTexasDan's Avatar
Old 07-12-2010, 01:03 PM
Nice find Dan, thanks!
Dz1rfj
07-17-2018 10:29 AM
Dz1rfj
09-16-2015 03:44 PM
sadepol01
09-11-2015 05:26 AM
1964Daimler
09-09-2015 11:28 AM
hoodun
09-07-2015 07:02 PM
Quick Reply: Door Handle Rubber Gasket
