Door Hinges
Old 01-11-2012, 02:01 PM
GGG is offline
Received 16,852 Likes on 12,186 Posts
Originally Posted by Jag13cat
HINGES FIXED!! - NO MORE METAL POPPING SOUNDS!!! I discovered that the two small nuts of the check arm (see Gus's diagram above) mounted on the door, which are somewhat recessed were loose. A quick tightening and the door swings smoothly.
Think yourself lucky you've only got loose nuts.
The metal frame is so thin on the XJ saloons, it rips the entire checkarm through the door.
  #42
Old 01-11-2012, 05:53 PM
Alag's Avatar
Loose nuts. Enough to make your eyes water
Al
  #43
Old 01-12-2012, 03:22 AM
Frog's Avatar
Originally Posted by Gus
Did you look at the hinges?
I'll have another look over the weekend and probably end up removing the door card to see what's going on in there. I found these 2 photos of the stay, which will hopefully help me get to the root of the problem.
  #44
Old 01-12-2012, 06:34 AM
Jag13cat's Avatar
Default Door Hinge popping
Frog;
Sorry to hear the problem wasn't easily solved. I was confident from my own experience, it was a matter of tightening the two nuts on the check arm (in your pictures). Removing the door panel and looking inside will provide a better opportunity of getting to the root of the problem. As mentioned in a previous post in this thread, the check arm has been known to pull from the door. Possibly your check arm was pulling from the door resulting in a smalll tear in the metal with the resulting popping of the metal each time the door was opened.
  #45
Old 01-12-2012, 08:07 AM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
That is the stay, making sure it is tight and the shaft is clean and lubricated. The other problem is at the hinges and you should check the bolts for them as well.
  #46
Old 10-18-2012, 12:28 PM
jagosaurus's Avatar
My problem is no noise, since the checkarm stopped working entirely.. Free swing baby
99xk8guy
05-28-2024 09:36 PM
99xk8guy
06-05-2023 06:28 AM
kevinl
10-31-2019 06:15 PM
Bc xj
09-17-2015 06:34 PM
RaceDiagnostics
09-13-2015 02:22 AM
Quick Reply: Door Hinges
