Door lock question - RESOLVED
Getting to know my recently acquired XK8 convertible
according to owners manual pressing the red button on the remote locks the car and arms the alarm. I get the flashing light, light on the shifter console etc. However I can still open the door. I hear a beeping which will set off the alarm unless I use the unlock button
But is the system operating as it should if I can open the door?
Also when putting the car in drive should the doors automatically lock?
Last edited by GGG; 11-27-2019 at 01:02 PM. Reason: Add "RESOLVED" to thread title
Randy,
1) no not normal. Sounds like door doesn't lock with alarm activation. Look in from outside, does inside handle move in with arming alarm, out with disarm? It should.
Get in car, start it up. Press handle in, can you reach out and open door with outside handle? (Assumption: press inside handle in, it stays in.) Checking to see if lock works at all here.
2) lock in drive is a software option set at dealer. It can be either way.
John
John
DavidYau (11-19-2019)
Randy,
John
John
Maybe push rods in the door latch mechanism
Randy
I would first check the push rods within the door mechanism are seated. GGG previously sent out this pic.
There's a recent thread from Scardini1 which provides updates to Rev Sam YouTube video and Gus' How To guide with good tips. Link below.
https://www.jaguarforums.com/forum/x...-guide-185085/
Johnken (11-20-2019)
Randy, how about that part about manually pushing interior handle in, reaching over to outside handle. Is door locked / can't open?
This will help decide: electrical or mechanical.
Let's not forget that the same thing is happening to both doors. Leads me to: Why aren't the door lock actuators getting any signal ever?
What the hell: Randy please confirm that key in door produces same failed results.
John
John
Door lock
thanks John. Car is in the shop now (green shower syndrome) so I can’t check it but l noticed fuse #2 on the passenger side fuse block is labeled door actuators. I’ll start there when I get her back
Good eye Randy, I missed that one in the fuse chart.
Hey, if not too much trouble, could you do the test to see if inside door handle can manually lock that door? (Push inside handle in, does outside handle open door?) That way we can file that away for future help and testing.
John
John
Your the first one I have found who has taken their car in to have it done. Would love to know how you get on. Thanks!!
Door locks resolved
Yep that was it. Was that way when I got the car. New fuse and now I have locking doors.
GGG (11-27-2019)
I am curious. You say its in the shop because of the Green Shower. Did you take it to a dealership? Hope you dont mind me asking but how much do they charge? Are they going to use genuine Jag hoses or others? Doing both lines or one?
I took the car to an independent British car repair shop. They did the pre purchase inspection. I read thru the DIY post and it was probably dIY doable. I am 75 with 2 knee replacements and it is getting harder and harder for some projects. Also this is my winter home so I am building up my tool inventory slowly! My concern was damaging some of the 16 year old plastic trim pieces. They used top hydraulics hoses and charged $1300. Another shop that I have no experience with also quoted $1300. I bought this car knowing there is no such thing as a cheap Jaguar
DavidYau (11-27-2019)
