Door Panel Clips
Door Panel Clips
2 broken door panel push pin retainers, HELP.
I have just removed the door panel on the drivers side and find that someone not very carefully removed the panel of my 2004 XK8 before me.
2 of the mount that hold the push in door panel are broken so will not hold a push pin. Does anyone know if this plastic mount is available so I could just glue on a new mount, or has anyone ever successfully repaired these.
hicat (01-17-2015)
The smaller yellow one is not available but the triangular one is. It is common to break them when removing the door panel.
There is even a service bulletin on how to fix them:
http://www.jagrepair.com/images/TSB/...r%20Adrift.pdf
C2N3836 or C2N3837 depending on the side.
Yann (09-25-2021)
Thank you, this forum is invaluable.
It has been a while ago but I was able to get both sides from Gaudin Jaguar in Las Vegas.
Direct JPLV Porsche Parts.com
Reading another post about a member that created an iPhone Dock with a 3D printer, he indicated the part did not hold up when exposed to heat (installed on the coin tray) and warped.
The following 2 users liked this post by daro31:
intltrade0823 (06-16-2018),
RJ237 (12-29-2014)
I've also been in contact with my local dealer and they said these clips are not available. I'm at a loss with both of my door panels annoyingly rattling.
Door Clips - Availability
Just this weekend I repaired mine. I was waiting to get the remote top control module and installed it at the same time. I was able to order the top corner triangle part and got it from the dealer. It took about 3 months to come as thy were on back order. The centre clip I repaired with a combnation of fabrication and automotive goop. The top clip hot melted to the door panel no problem.
