door side mirror switch plus window switches
Part number is LJA6332AG.
Here is a link to buy one new under list:
http://www.gaudinjaguarparts.com/par...&siteid=214626
djpxk8 (06-02-2011)
I've now ordered from the nearest dealer (ouch), and even then haven't got it after 10 days - they say it will be here tomorrow....
I'm not 100% convinced my problem is the switch - both mirrors work ok up/down, but neither work left/right when controlled by the switch. I took it apart and cleaned it - made no difference. But when I pressed the 'memory' button I'm pretty certain the drivers mirror went moved vertically (indicating the mirror is ok) - hence why I've bought the switch.
-Steve
Received 2,190 Likes
-Steve
The new switch has fixed my mirror problem, so if you'd like you can have the old switch. Just to be clear, it's faulty - it won't move either mirror in a left-right direction, but otherwise is ok. Cleaning the internals made no difference to this fault.
I'm guessing that you could make one good switch from the pair by swapping the tops (if that is what's broken on yours).
If you pm me a shipping address, I'll try and get it out to you on Saturday AM
-Steve
99xk8guy
06-05-2023 06:28 AM
