Door striker 2004 XK8 Convertible - RESOLVED
Need help trying to get a striker plate for the drivers door on my 2004 jag xk8 convertible. Its the one fixed to the frame with two torx screws holding it in that the door latches on. Cant find one anywhere. My door had the droop problem which i intend to fix ( cracked steel around the lower door hinge ) and the door does drop about 1 inch but is ok when closed , but the striker is wearing out hence need a new one. E bay and amazon no use if i had a part number maybe jag dealer might get one. A used one in good shape would be ok , think RH and LH are the same.
Last edited by GGG; 12-18-2020 at 09:46 AM. Reason: Add "RESOLVED" to thread title
