door window fault
door window fault
opened the passenger door on my car today to get somthing out ,when I shut the door it would not shut properly..the window was fully up so the glass was hitting the trim.when you pull the handle even with the door open the glass goes down about half inch when release it goes back up..have to let the window down from the drivers controls to shut door the sent it up..tried to reset but still the same..any help would be usefull..
the big hammer is standing by
looked at sams videos and know how to remove panel and adjust window..going to have a go thursday
-How are you doing the 'reset'
-What is the voltage across your battery terminals?
thanks for the quick reply..
ignition on window all the way down still holding button wait for click.. window all the way up still holding button..wait for click..
done this before so I know im doing it ok..done it on the drivers door when its lost its mem..battery in good condition..winter here so i make sure batt 100%..any ideas?
The hardest part about removing the latch is getting the rods that go from the outside handle down to the latch disconnected. The ends are made of plastic and they just snap on to the latch mechanism, but it is hard to pop them off, and I ended up breaking one of the plastic bits in the process. I was able to repair it simply by drilling a hole in the plastic piece, then I lined up the hole I had drilled with the hole in the lever on the latch and I zip tied them together.
