Door windows are erratic
What it could be is . . . any or all of above. Suggest you review the many threads on each. Removing the door card will give you access to switchpack and most wiring & connectors. Access into mirror drive motors is also documented for cleaning and lube. Suggest you start with the former.
Cheers,
Ken
Cheers,
Ken
Charbinjr (06-06-2017)
As Ken says, it could be motors or switch pack.
Reports on the forum suggest motors die rather than become erratic but that's only indicative of a faulty switch pack perhaps being more likely.
Some members have successfully dismantled and repaired the switch pack but I'm not one of them. When I tried it on my 2001 XK8, tiny springs and copper contact blades flew all over the place but fortunately I was able to source a replacement.
Charbinjr (06-08-2017)
