Double Din In XKR - Got it to Work!
Old 06-19-2012, 09:14 PM
GordoCatCar's Avatar
Not feelin' the love for your blue center panel. Forget about trying to 'wrap' your center panel...or even find a match to existing panels. Get another set of wood panels from a parts car. They pop off easily and you can have the interior looking good again w/o much hassle.
Old 06-19-2012, 09:38 PM
enderle's Avatar
You'd have to see the color scheme, in this one I'm not convinced wood really works. But I have time and this is a project car. I have replacment panels for every part and that is what I'm wrapping anyway. One panel part I'm concerned about pulling is the one over the Air Bag. If you've had yours off, any trick to that?
Old 06-19-2012, 10:27 PM
ccfulton's Avatar
Received 1,107 Likes on 764 Posts
Originally Posted by XKRacer
Not a problem
I'm on the fence about the matte look, but the wrap is an interesting idea. What do you think of them compared to a respray? Do they hold up? Cost effective?
Old 06-20-2012, 02:18 AM
XKRacer's Avatar
Originally Posted by NikasilNik
Just make sure nobody comes along and photoshops your photo Tony and claims they created the car ..................... sorry mate , wrong forum LOL
Great job
All the very best mate , see you at Silverstone for the classic ???????????
Nik
I will be at Silverstone ...... Dont you just hate it when somebody else claims your work for there own
I dont think he has posted since that escapade LOL
Old 06-24-2012, 07:43 PM
enderle's Avatar
Default Redid Dash in Black and Black Graphite
Messed around with silver, more blue steel, and even some gloss black. I liked this the best let me know what you think.
Old 06-24-2012, 08:17 PM
Jag#4's Avatar
This is the best look so far. I'm partial to the wood myself, but this black look matches the rest of the car much better.
BTW, is your a-pillar and header done in a lighter color? Or is the exposure on the picture off?
Old 06-24-2012, 09:04 PM
enderle's Avatar
Default Headliner
Headliner and A-Pillar are stock. Nearly identical to my oatmeal XK-8. You'd of thought they would have gone black, blue or even gray with this car. Top is black, go figure?
  #28
Old 06-25-2012, 04:03 AM
GGG is offline
Received 16,851 Likes on 12,186 Posts
I'm also a wood fan but the black looks much better than the centre blue panel. It's a natural blend with the console and dash top.
You must be a wrap expert by now.
Old 06-25-2012, 06:43 AM
Frog's Avatar
This.
  #30
plums's Avatar
Received 2,181 Likes on 1,621 Posts
Thumbs up
Originally Posted by enderle
Look at the configuration in the trunk of my XK-8 and the selenoids are in a different configuration, make the change in the XK-R, and presto everything works.
Almost worth it to just put a good relay in the unused position so that it does not matter when someone gets it wrong. Or, tape over the unused position. Yes, it really does happen. The spare relay approach is better. In the dark one might miss the tape and poke a relay right through the tape while a needed position goes unfilled. Don't ask
In the process of all of this (went through every fuse) discover why the car is running hot, evidently the intercooler pump fuse is blowing. That damn pump is a $500 item so my hope is that the wire was shorted when the blower was pulled off to fix the fuel rails. However bet is that the pump has failed. No visible warning to the problem other than the car cooling fans run excessively and nasty pinging. Heat may be causing one of the smog sensors to fail but I just got lucky on the fuse.
Good tip on the fuse. It's not usually on the checklist when people start hunting for the cause of extended fan operation. Apparently, the Bosch intercooler pump from a Ford Lightning is a good substitute, and it flows a few GPH more. Around $100.
  #31
Old 06-25-2012, 06:47 AM
plums's Avatar
The monochrome works. Black out the shift knob, and you're good to go.
enderle (06-25-2012)
  #32
Old 06-25-2012, 02:15 PM
Marsden's Avatar
Looks vastly better now! It's been fun and educational watching you work this out.
You could do this for a business you know?
Wow now that's a good piece of information!
  #33
Old 06-26-2012, 07:33 AM
Bills's Avatar
I like the black. Brings the whole interior together and tones down the blue.
enderle (06-26-2012)
  #34
Old 06-27-2012, 01:49 AM
Frog's Avatar
Much nicer
enderle (06-27-2012)
  #35
Old 06-27-2012, 04:44 PM
moonpetal38's Avatar
Love this. My hubby wants to put a double din in my xk. He had a question tho. Where did you put all the other switches under the climate control? Thanks.
  #36
Old 06-27-2012, 05:13 PM
Received 6,307 Likes on 5,495 Posts
They're in the glovebox.
moonpetal38 (06-28-2012)
  #37
Old 06-27-2012, 06:37 PM
enderle's Avatar
Default They weren't moved.
Didn't move them, they are right where Jaguar put them in the first place. This shot shows that, this was the initial dash treatment (blue) since went to black and black graphite.
  #38
Old 06-28-2012, 05:57 AM
Thanks. After asking, hubby saw it in the other posts. It sure helps to look doesn't it, which I thought I did but not very well apparently. I sure appreciate you answering though. This is definitely his next project.
  #39
Old 06-28-2012, 10:25 AM
enderle's Avatar
Default Get a good installer
I found the installer I used by asking a guy who had a leading show car who he had used to do his installation. The mount is difficult to do, clearance is pretty tight. You want someone who does difficult installs to attempt this otherwise you're likely to have problems. You don't want someone who doesn't do much fabrication to attempt this.
  #40
Old 07-01-2012, 12:04 AM
enderle's Avatar
Default Latest dash
Moved graphite to the air vents and replaced the shifter. Think the air bag cover needs something but also think I'm close.
Attached Thumbnails Double Din In XKR - Got it to Work!-p1000306.jpg   Double Din In XKR - Got it to Work!-p1000302.jpg
Quick Reply: Double Din In XKR - Got it to Work!
