Drain plug for block?
Should the block be drained when chaning the coolant? I know there is a drain point behind or above the starter but i found a socket head bolt like the one on the supercharger bleed point although a bit smaller on the other side of the block. Is this also a drain point?
JTIS only displays the one drain plug which, I could not reach, behind the starter. I guess if you had a lift it would be easier.
I just drained all that would come out and refilled with a premixed 50/50 solution. That was easy but a flush would be appropriate if you are changing types of coolant.
The following 2 users liked this post by motorcarman:
Bob OB (04-27-2013),
test point (05-15-2011)
aholbro1
08-05-2021 05:02 AM
chatmanx
09-11-2015 07:17 PM
