Drain Plugs?
[img]blob:https://www.jaguarforums.com/8ee2a67...7-e493f743292a
These plugs. Found one on the ground under the car. One on each lower front corner. When I
pulled out the second one it looks like they are covering a threaded hole.
HI not sure but looks like the ones i had found under my car some time ago ,there were lots of round grommet things in the floor of the car ,cant remember how meany now , they were a mixture of metal and plastic and rotting out , i had them removed and the small holes plated over then the floor of the car waxed, never found out what them small holes with grommets were for , hope this helps.
DavidYau (03-03-2019)
Car production lines left all sorts of weird bits and bobs, in cars, just for rapid handling in the manufacturing processes. Wouldn't be surprised if these holes were meant for that and the cheap plastic covering plugs would normally be covered up, in old cars, by underseal/waxoyl so we can't see the horrors underneath.
As a former weld inspector, paint expert, sometimes I believe ignorance is bliss, otherwise you'll have nightmares.
Looks like the plugs could be used as a wine/beer stop!
Thank you Graham. My kids are helping me figure out Google Photos so I should be able to insert photos properly soon. Regards
Those plugs were part of the package in the boot for new cars. During PDI we fitted license plate mounts and removed the tow eyes.
One went into the tool kit under the spare wheel and the plugs were installed in the holes to prevent the ingress of dirt.
I fitted DOZENS. I think I still have a few in boxes of trim and fasteners somewhere.
bob
bob
Bob,
I recall the plugs on my 2005 Final Series XK8 4.2-S were threaded and not push fit. This was probably to help stop the threads rusting because the one time I needed to use a towing eye on my 2001 XK8, the thread on the vehicle was so rusted, the eye would only go in a couple of turns!
04Sport
06-19-2015 01:31 PM
arath25
09-01-2014 07:23 AM
