Draining the entire tank through fuel filter connection
So, I'm 6 14 gallons of petrol/gas into a fuel filter replacement. I expected a small amount of fuel, but I started collecting it when it was spilling from the driveway into the street and my lawn. Four Six Fourteen gallons collected, I expect the next 10 8 0 gallons will come out too. (note: no more gallons left to come out)
This seems like an inefficient way to transfer fuel between my vehicles, any thoughts on stopping the constant but relatively slow deluge? At this point, it will stop either
1. because of something I do short of dropping the tank, or
2. it runs out of fuel since I have a plethora of cars to transfer it too.
I assume siphoning from the fill is not an option because of some anti-siphon feature?
Problem solved, out of gas.
Received 4,341 Likes
crbass (04-04-2020)
Immediate problem solved, no more gas. I guess I'll dig into the fuel system some time soon. Probably not with a fulliish tank.
crbass (04-04-2020)
Was wondering. Does this have any other implications (other than every leak siphoning out the whole tank), or should I just make sure I'm low next time?
Dale, did not have that trouble changing filter on my 2000, but when changing the fuel pump a couple of months ago. I drained it from the fill hole.
Used a 1/4 inch inside clear plastic hose attached to the hand pump I got at HF. Took a while and it was only 6 gallons, so a electric pump would be better.
The length installed from the mouth of the fill hole was 44 inches and it got all but a pint or less out. The two pipes set up from the bottom of the tank by about 1 and 1/2 inches, so a gallon could still be in there.
Yep; we can definitely help. We just went through a fuel pump replacement on Wayne's 2000 XK8 back in January. Wayne now has all the tools needed (especially that skinny 22-inch-long flat-blade screwdriver with the custom-ground tip used to release the fuel lines underneath the car) and we also know exactly which curse words to shout at each stage of the job...
The following 5 users liked this post by Jon89:
cjd777 (04-05-2020),
crbass (04-05-2020),
DavidYau (04-07-2020),
motorcarman (04-05-2020),
sklimii (04-12-2020)
RobHathaway
01-03-2017 04:33 AM
1964Daimler
08-03-2016 08:32 AM
RizwanSharp
17
11-15-2010 09:40 AM
