Drive cycle & code resetting question...
Hey gang!
Quick question...after fixing my problem that induced my 'check engine' light, I disconnected the battery for a while, reconnected, reset the codes with my ODBII, and now I'm waiting for it NOT to read P1000 anymore so that I can get my emissions testing performed (required in the great state of Arizona).
While I'm driving the heck out of this cat at every opportunity to get it to go through its drive cycle, another check engine light came on with a goofy code that was a simple fix.
Here's my question: If I connect my ODBII to the cat and erase that code, will this also reset my drive cycle back to square-one?
I have over 2 weeks worth of driving so far and I would hate to have to start this all over again.
This drive cycle crap is killing me!
Yes if you erase the code it'll clear all the OBD monitors and restart the drive cycle.
The drive cycle tends to be detailed in the codes PDF for your car/year. (Is for the S-Type, for sure.)
What you can do is clear codes, then watch to see which monitors haven't set after some ordinary driving and refer to the PDF then. Or post and ask for ideas.
Evap often needs fuel between this & that (say 15% & 85%) but also an overnight cool down.
Most of the codes reset in a few miles. Evap requires gas in the mid range (between a quarter and three quarters full tank )and you can't slosh the gas from when it is cold till when the monitor sets. This was a huge problem for me because I live on a hill. I left the car overnight at the airport, started flat, drove easy, and it reset before I got home.
The following 2 users liked this post by Dennis07:
Jag#4 (05-18-2014),
test point (05-19-2014)
Do I need a more elaborate OBD reader?
If so, any recommendations?
Received 6,313 Likes
On most of our cars, such driving will be enough. With a fault or a marginal code/no-code fault... sadly sometimes not.
EVAP can be awkward due to the need to have cold start, not too little or too much fuel and little or no sloshing. for example - gets tougher with newer cars as the laws were tightened and that left car makers with few options.
