Driver’s window won’t return into roof XK8 Convertible
The windows are supposed to drop down when opening the doors. However the driver’s window drops but doesn’t return. Then on each subsequent opening of the door, it keeps dropping down. I tried a YouTube suggestion of holding the button up till hearing a small click, but that hasn’t helped. Any suggestions?
If no luck with the above, you might be looking at a bad micro switch in the door handle. Not a bad job, Jon89 has a good writeup on when we did his.
The hardest part was getting the new switch bend right to hit the cam at the right time.
Good luck, and let us know after checking the battery.
Joesstuff
04-04-2019 10:08 AM
