Driver Airbag indicator
However, I don't believe a 'regular' OBDII reader will read the Air Bag (Safety Restraint System) codes - though more expensive readers will (there's a thread somewhere here with details).
However, the good news is that the light is probably flashing in a pattern (showing two digits). e.g 'Flash-Flash (gap) Flash-Flash-Flash (longer gap) is 23.
You can look these codes up (see attached) to determine where the fault is...and probably won't need to use an OBD reader (I managed to locate a bad connector this way)
Good luck,
-Steve
Johnken
09-15-2015 05:46 PM
