Driver door panel loose '99 XK8 conv.
The U-shaped brackets usually can be repaired with JB-Weld (regular, NOT QUIK SET).
If it is too damaged and you need to replace the part number for the upper rear one is C2N3837, which is the most common one to break and there is a factory bulletin on. It woiud need to be fastened with epoxy or strong hot-melt glue.
Jaguar Parts - Direct JPLV Porsche Parts.com
The pin fasteners are part number KTC100017
If any receptacles in the door are also broken they are KZV100010
Next time please visit us in the XK8/XKR section...not general tech help...you will find lots more help and cameraderie there.
99xk8guy
06-05-2023 06:28 AM
