Driver power seat/tilt steering malfunction - Resolved
Hi, to everybody today my driver side power seat went totally dead as well as the tilt steering function.... but the telescoping still works when the key is placed and withdraw. Interchanged the driver seat module with the passenger without success. No broken tracks on the pcb seen.
All fuses check good, as well as the voltage on the driver fascia fuse box. Is there any relay, or remote fuse box related to both the driver seat and the tilt motor... can it be the BCM????..... Any idea is welcome
![Icon Snow](https://www.jaguarforums.com/forum/images/smilies/icon_snow.gif)
All fuses check good, as well as the voltage on the driver fascia fuse box. Is there any relay, or remote fuse box related to both the driver seat and the tilt motor... can it be the BCM????..... Any idea is welcome![Icon Snow](https://www.jaguarforums.com/forum/images/smilies/icon_snow.gif)
This is a link to the oneline on the car
Link http://www.jagrepair.com/images/Auto.../jagxk2001.pdf
Look at Fig 12.1 and you will see a ground that I would be checking then I would look at the seat switch pack. From experience I recommend is that you check the fuse with it being removed if you haven’t already.
ps1726 (11-28-2012)
ps1726 (11-28-2012)
Dicque
09-19-2015 12:53 PM
