Driver Power Window Issue
https://www.jaguarforums.com/forum/x...solved-158391/
Found it. It reminded me that there is an upper channel in the door, midway up, inside facing window, that support the travel of one of the regulator arms.
I am perplexed that yout window does not display cockeyed travel. If you think about it, impeding any one arm or channel movements will not impede the other (s), which would push one side up = cockeyed. Ah just thinking out loud to help you shoot the problem. If you do replace the regulator the link will help.
John
John
John
John
Window travel I'd degraded when going down. Slow to get started but picks up speed. Going up hardly any movement without my assistance. I have to grab the edge of the glass and pull up. With that said I did clean the mechanism and guide rails. The window guide was easy to clean. The rails in the door were much harder. There is also that Middle rail that guide the arms. I was suspect on the plastic guides. One of them was chipped where the arm attaches and the clip holds it in place. I don't notice any problems in this area. When I activate the motor. I do see a slightly Cockeye travel at the beginning of the movement. And I can manually move the window from front to back. I compared to the pass side and it's identical. If there was something causing too much friction in the inner door guide rails. How would I go about cleaning those. The rails closest to the latch is easier to get to the one close to the hinge is difficult. I can only get to the bottom half. I have ordered a new set of plastic guides. So I'll wait on those then resume the troubleshooting.
I'm still baffled about manually testing the motor. I haven't gotten it to move with direct connection to the motor.
On my 99xk8 my window stopped working complerely. All I could hear was a clicking sound when I used the wondow switch. I replaced the motor tried a different switch and used a different door module. Same thing it didn't work.
It turned out to be that the ground connection between the door harness and the car body near the door hinges. It was corroded a little.
It might be worth a try to disconnect the connector and the reinstalling it. It doesn't cost anything and doesn't take much time.
Norri (07-29-2017)
