Driver seat is stuck and will not move. Tried the usual suspects.
Within an hour of getting the car home for the first time ( bought used ) my wife moved the driver seat forward to suit her and the seat stopped. Now it will not adjust, go up nor lumbar support. SO, I searched the forums here. First I disconnected the battery for 15 minutes, plugged it back in, didnt work. Then, I disconnected it again, swapped the control modules, and the driver side worked on the passenger side. Looked at all the wiring I could see, and then checked fuses with an ohm meter. Nothing, and the seat will still not move. Everything else works. Any ideas? I'd love to get the seat out to check things. I can see two torks screw per side in front. If I loosen them will I bet the seat up high enough to be able to see anything? And where are the rear bolts for the seat anyway? Seems like this is a common problem. And what size are those torks screws? Thanks!
Plaster
16
10-31-2013 03:51 PM
