Driver window/ driver side mirror
Hello everyone,
I've been having issues with my driver window not working in my Jaguar 1998 XK8. It has the v8. The driver side switch works the passenger side window, but I can't seem to get the driver one working. I wasn't able to find a fuse dedicated to the driver side window/ mirror. Am I missing something? Just confused hoping to get some guidance on the matter. If someone had a wiring diagram for the switch, that would also be helpful too.
Thank you.
Thank you.
I had the same issue the mirrors not functioning and it turned out that moisture had got into the switch pack. I stripped the switch pack down to see if i could do anything but the contacts on the circuit board had corroded through. I bought a replacement switch from Auto Reserve jag spares. Hope this is of some help. Good luck.
Johnken (04-02-2023)
