DRIVERS DOOR OPEN warning message
Car's been parked for about 28 hours. Bliped the remote unlock button and got the double-chirp. Pull drivers door handle but door was still locked. Inserted key to manually unlock door to get into car.
Car started but DRIVERS DOOR OPEN warning message lit up on dash. The following also not working:
Went through the forum and the cause can be due to either :
Gents, the last remedy above is obviously the easiest to apply, so I would try that first thing tomorrow morning, after first locating my radio security unlock code.
Do you guys have any other suggestions for me and places for me to look at to solve the problem? TIA.
- driver and passenger window switches on driver-side
- door mirror adjustment for both doors
- passenger side door mirror dip when reversing
- cannot lock car with remote
- OBD code showed nothing
- a faulty door latch micro-switch which would need replacing, or
- a poor grounding connection for the driver control module which needed a thorough cleansing, or
- just a 1-off random glitch, which can be cured simply by disconnect the cable from the battery positive terminal and touch it to ground to reset all modules.
All together sounds like break in connection to drivers door. Too many disparate things to be just door switch.
I once read about someone finding a bad wire harness connection onto door. I bet the key in door doesn't do anything either. I'm not suggesting fuse because of message .
Gotta run John
Gotta run John
Pristine97XK8Convertible (08-02-2017)
The following 2 users liked this post by avern1:
Johnken (08-02-2017),
Pristine97XK8Convertible (08-05-2017)
Further repair update:
Swapped the two modules and got back control of drivers window up and down, drivers side rear view mirror controls, seat memory recall. The warning message now shows Passengers Door Open. Locking car with remote now works, but you have to manually lock passengers door, otherwise car will chirp on and on... Unlocking with remote is weird, as the drivers door lever will cycle thru the lock and unlock position 3 times before stopping. I am also unable to open the petrol (gas) refill hatch by pressing the button adjacent to the boot open button. A quick pull down of the boot lining around the fuel hatch area revealed a manual opening lever attached to the filler neck which opened the hatch.
Now that the failure has been positively identified, had a look in eBay for a used replacement door module LJA2120AG and found many to choose from at an affordable price, so I would not bother repairing the faulty module because the top cover has been glued on solidly to be water-tight and is very difficult to pry open without causing damage.
Thanks for watching gents, and until the next fault shall we meet again...
Cheers!
Cheers!
Pristine97XK8Convertible (08-06-2017)
