Drivers door window out of sync on convertible
Received 6,354 Likes
Thanks I will first try the reset then if necessary disconnect the battery and discharge any capacitors in the system. If that does not work I will remove the door panel and locate the microswitch and door module. Any chance you might know where I might find part numbers for these two items and how can I test them?
See this thread starting at post 6 for the micro switch replacement.
https://www.jaguarforums.com/forum/x...roject-118210/
Thanks for this hint. I just joined, and was searching posts because my 2002 XK8 windows were not operating properly after a battery change. I thought I had reset them, per the operator's manual, but missed the "click". Resetting again, this time with a "click", solved the problem. Thanks!
Jag13cat
11-30-2015 06:48 AM
