Drivers door / window problem 1997 XK8
I just got into car and on message screen it says "Drivers door open" but door is closed. Automatic locks not working either. Drivers window dropped to it's opening level but will not work with switch or come back up. Neither side works. Car stays outside and expecting rain. Can I reset this? Obd2 reader? Battery terminal neg to pos?
Help!
thanks
Jack
1997 XK8 convertible
Help!
thanks
Jack
Re input
Help!
thanks
Jack
Help!
thanks
Jack
please send thoughts.
thanks agsin
Jack
First get the trunk dry, may components in there that are expensive to replace.
Try a hard reset on the battery, disconnect the positive cable at the battery and hold the cable on the negative terminal for a few seconds. This resets everything, be sure to reset the window travel limits afterward by sitting in the car with the door closed, run each window up and down a couple times holding the switch each time until you hear a click.
Did hard reset, no luck. Where is micro switch?
I checked Facia drivers fuse panel at night and also noticed that interior lights do not go on when I open the drivers door. It does go on if I push light buttons on top. Trunk is now dry, the hurricane was a bitch but could have been worse. No water anywhere but trunk under and on top of battery also in tire area.
Jack
Jack
Would the micro switch kill outside key control, interior lights upon open, give me message door open, window on drivers door in open position but will not go up or down, window switches on drivers door Dead? I will gladly do it but part expensive. If wrong part I am out a lot.
Jack
Guess I will wait to see if it happens again. Micro switches usually break and don't repair themselves.
Advice?
Jack
1999 XK8
Jack, many of us, myself included, have had intermittent door switch failure. Some report wd40 fixed, mine corrected as I disassembled mechanics to get to it.
I forget when they changed the circuit, but as Bob said, if display says door open car thinks it is. For 97 and 98: Puddle light is on, window will not raise to seal when latched.
Try spraying the door latch with WD40 and operate the door open and closed a few times. If it does not clear the problem then it might be a good idea to do a little troubleshooting. Often the door latch is forgotten and it becomes dry and sluggish without lubrication.
This is a link to the door latch and the micro switches associated with it.
Jack, not sure if we answered. The switch is in the door latch.
You know I just thought. Since the switch contact is either open or closed, wouldn't it be nice if there was a test point you could easily reach with your multimeter.
Does this switch go to a door processor module inside the Door? If so this idea isn't going to help much since you'd have to take door panel off to get to any analog connections.
Otoh, does a wire go to the body processor module behind the passenger air bag? If so there's going to be several feet of door switch wire to find and set up a test point.
This question "bad switch or not?" Comes up often enough. I figure it's a long shot, but wouldn't it be nice to have a test point in the car.
anyone agree?
i thought car got hurricane water trashed
thanks
jack
But about 18 months ago, I had a problem opening the drivers door. The latch would open half way or pull to lock. It did it for 12 hrs then went away now this.
I have owned 10 E-types, an SS, 120, 150, Mk2, XJ6 series2, 6 Xj12 convertibles and never had strange issues like this. I always knew how to fix the older cars. These newer cars stump me.
thanks to all
Jack
Car wasn't behaving correctly even for the case where the microswitch - or the signal from it - was stuck in the door open position. So probably some condensation in the door control module - exceeding relative humidity specs can play havoc with processor modules - and now OK since being dried out, and the microswitch is probably OK, too.
This fixed my 05 XK8 Windows
Switch ON the ignition.
With doors closed, lower the window fully (to the stop) and hold the switch in the "DOWN" position for a further five seconds.
Raise the window fully (to the stop) and hold the switch in the "UP" position for a further five seconds.
Repeat for opposite door.
Switch OFF the ignition.
What about the SLCM located beneath the fuse box in the trunk. He did state that the trunk had standing water, and the SLCM is not a sealed module like the ABS module that has to be cut open. Could the SLCM have caused the prior and currently corrected problem? Is it called the Security and Lighting Control Module, or the Security and Locking Control Module?
