Drivers headlight problem
Last week noticed my front drivers headlight was out. Checked the bulb,it's fine. High beam headlight works fine,when I switch to on with the headlight stalk in car and the dip beam flashes then goes out. Where should I start looking?
_________________
1997 XK8 (added by GGG)
_________________
Last edited by GGG; 10-16-2019 at 12:38 PM. Reason: Add Model & Year details from post #3
First a couple of things and then I will get to your problem.
1. It would be helpful if you went to the User Control Panel and added your vehicle details so we aren't guessing as to what you are working on.
2. This is the XK8 forum the link below is to the correct forum for the XJ8 you have.
https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/
The most likely problem is the bulb holder is corroded or the ground connection is corroded. Try removing the bulb and cleaning the contacts within the holder. Then follow the wires to where the ground branches off and clean the ground connection. One more thing to try is swwap the bulb with the know working one and see if the problem follows to the new location. It might be that the filament is lighting and then gets hot and opens.
+1 to avern1’s comments.
Still worth checking out this link below to the “To The Garage” Youtube channel. John has a triology on the XK8 headlamp. Bit slow but very thorough.
https://m.youtube.com/channel/UCT2ZywCQe9dtTi2qvbQNEdQ
avern1 (10-16-2019)
1) does it light for full 25 seconds with engine off remote control button pressed?
If yes, points to wiring at the stalk.
If no, sounds like its happening between the body processor module and the light bulb.
If yes, Does the flicker usually occur within 25 seconds with the stalk switch? If yes, it's pointing to the switch in the stalk.
2) your description of the stalk operation makes me wonder if a wire connection came lose. They are soldered to a small circuit board at base of stalk. I admit I forget where in the circuit the left and right headlights are controlled by individual wires (as I recall, there are individual fuses for each side), lose wire here usually affects both lights IME.
but here's an easy test: jiggle the turn signal stalk lights on - does it impact the issue? If so we can help troubleshoot the unsoldered wire.
BTW, do you have auto headlights? If yes does it matter if in auto or manual headlight on position?
John
John
John
John
