drivers seat belt
Old 10-14-2011, 06:53 AM
dennisw's Avatar
Default drivers seat belt
the drivers seat belt on my xkr dosnt go back into it retaining hole..the return spring has gone weak..can it be fixed? as it tends to get caught in the door on exit..any help would be good..just to add its goes back if you help it
Old 10-14-2011, 07:15 AM
Reverend Sam's Avatar
Received 1,261 Likes on 565 Posts
That's a good question. Mine is slightly weak. Usually it gets twisted slightly and then binds before it can retract. This might be another project for me to work on. I'm sure there has to be a way to tighten the spring.
Old 10-16-2011, 11:19 AM
dennisw's Avatar
poor response on this one eh sam
Old 10-16-2011, 11:33 AM
I think it's just one of those things that people don't even think about. Before you mentioned it I hadn't even noticed that mine was a little weak. But now it's going to bug me until I fix it. Thanks.
Old 10-16-2011, 01:38 PM
dennisw's Avatar
thanks to you cant wait to see it..i know youll do it when you have time
Old 10-16-2011, 01:47 PM
plums's Avatar
Received 2,183 Likes on 1,623 Posts
A common cause of weak return on seatbelts is that the belt has twisted on the takeup spool.
To fix it you may be able to unwind the belt and then feed it back in straight. If that does not work, then the retractor has to be accessed.
mcbeefsteak (11-01-2011)
Old 10-16-2011, 03:26 PM
mjlaris's Avatar
Mine's the same way, it retracts but is week and I generally need to help it. This is also true for my X-Type. Would be interested in a fix.
Mark
Old 10-29-2011, 08:14 AM
dennisw's Avatar
think we should keep this one going..cmon sam
Old 10-29-2011, 02:20 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
it is really easy to pull that trim panel and observe that seat belt, at least with the verts. The rear seat is only held in by those two bolts in front, and under the cushion near the footwells. Side panels take a few more screws/bolts, but thats it. there it is right there!!
Old 10-31-2011, 05:01 AM
dennisw's Avatar
the seat belts in the back of my car have never been used..i wonder if one of these would replace the divers belt?
Old 11-05-2011, 02:29 AM
H20boy's Avatar
I don't see why not, as long as its the same length and is mounted similarly. Give it a go!
Clamdigger
09-12-2015 03:43 PM
bavareze
09-11-2015 01:49 AM
wcourt3010
09-09-2015 04:34 PM
joey g
US Northeast
09-07-2015 06:28 PM
Dallas XK8
09-03-2015 12:17 PM
Quick Reply: drivers seat belt
