Drivers side floor rot, what the @#$%^&*
Received 6,320 Likes
If you are going to do it do it properly, I have done this many times and seen some really bad repairs done just to bite you in the *** later...
You start with this
![Name: IMG_0712.jpg
Size: 50.8 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/164574d1501273117-drivers-side-floor-rot-what-%40-%24%25%5E-%2A-img_0712.jpg)
Cut it out and dont be squeemish
![Name: IMG_0715.jpg
Size: 45.6 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/164575d1501273117-drivers-side-floor-rot-what-%40-%24%25%5E-%2A-img_0715.jpg)
Make a panel with a matching rib pattern and seam weld it in
![Name: IMG_0718.jpg
Size: 52.4 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/164576d1501273117-drivers-side-floor-rot-what-%40-%24%25%5E-%2A-img_0718.jpg)
Paint it, this car was changed to a dark grey so I used black
![Name: IMG_0719.jpg
Size: 42.9 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/164577d1501273117-drivers-side-floor-rot-what-%40-%24%25%5E-%2A-img_0719.jpg)
Then stick a rubber mat to it for good measure
![Name: IMG_0721.jpg
Size: 58.2 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/164578d1501273117-drivers-side-floor-rot-what-%40-%24%25%5E-%2A-img_0721.jpg)
A good tip... make sure you dry your carpet before you put it back as it will be soaked and will not dry of its own accord
You start with this
Dicque
09-19-2015 12:53 PM
