Drivers Side Fuse Box Layout Clarity
I would like some clarity on the layout for my RHD 1999 XKR Convertible drivers side fuse box, alll the stickies/PDFs I've seen seen for up to a 2002 seem to be very similar but the ampage layout on mine seems way out.
A pic of mine is attached with the top right 25amp fuse being blown but I also have a number of gremlins in the electrics.
Some charity would be most appreciated.
Received 2,434 Likes
They all look correct other than #1 (drivers seat control module) which should be 20A not 25A.
They are numbered (in v. small digits) top to bottom 1 to 9 in RHS column, 10 to 18 in LHS. Number 4 (10A) should have a yellow safety cover as it's an airbag fuse. See this snip from the '99 vehicle care guide:
Handbook is a tad large to attach. It's available for download via a link in the stickies here:
https://www.jaguarforums.com/forum/x...27/#post466034
Note that fuse locations are in the Vehicle Care document.
Fuses are 10 and 13 (both 5A) as above:- 10 is ignition-switched, 13 B+ always.
