Drivers side window closing slowly
There's an adjustment bolt under the door panel that holds the window regulator assembly. By loosening this bolt or nut ( I can't remember which) and adjusting the angle of the window regulator assembly you can find at which angle the window operates best and re-tighten the bolt to hold it there. Sometimes it travels a little with age/use and needs re-adjusted.
After an accident, my father's XK had an an aftermarket door put on with the guts from his door. He had the same problem and I was able to clear it up by adjusting that bolt.
99xk8guy
06-05-2023 06:28 AM
Dicque
09-19-2015 12:53 PM
