drivers window switch
Old 04-16-2017, 12:05 PM
macs99's Avatar
Question drivers window switch
Hi guys rebuilt car from ground up and am stuck on changing drivers side window switch. Age must be catching up, any help would be appreciated.
Old 04-16-2017, 12:28 PM
avern1's Avatar
Received 1,319 Likes on 1,004 Posts
You will need to remove the door card. Once that is done you can separate the arm rest and you will be able to access the mounting for the switch assembly.
macs99 (04-16-2017)
Old 04-16-2017, 01:06 PM
macs99's Avatar
Thanks for your help i think i went brain dead.
