Drrrr! Rocker rot!
Drrrr! Rocker rot!
So I went to check my lug tightness since I had my wheels road force balanced, and I noticed that my rocker right in front of the right rear wheel finally succumbed to the Pennsylvania roads winter treatments. I started poking at it and yes it was pretty bad. I’m no professional, but I’ve done some repairs before soI decided to make my own patch panel by hand, got it pretty close, and started putting it together when it started raining. Drrrrrrr! Hopefully I’ll be able to get it finished this weekend!
Timeisrelative (02-01-2020)
Damn Tin Worm is global
Well I feel your pain. I had a rust problem exactly at the same location. See my recent thread below for details.
https://www.jaguarforums.com/forum/x...ahrain-221142/
Well went out to finish today and as soon as I started it started a REALLY wet snow. Argh! Also probably going to have to cut higher due to as soon as I strike arc on a couple of spots, the factory metal disappears. Drrrrrrr! It looked, felt and sounded solid, but it must be a little bit thin. Add into the fact of laying on my side and having wet snow and a couple of small spalds going down my ear. I decided to give up for the moment. Smh
Timeisrelative (02-02-2020)
this is a lot of work to keep rust from coming back,but what I do in the American great lakes rust belt is flood area's with rustoleum paint.you'll have to remove inside panels for access but it doe's a great job.i paint doors [inside seem 4 inches],flood over rear wheel wells and front 1/4s,and plug all drain holes under rocker then fill rockers to top with paint,around 4 gallons then drain back into emty cans.this is allot better than rustproofing cause it gets into everything.P.S.i use a cardboard gutter,steve
The following 2 users liked this post by steven300:
michaelh (08-25-2020),
CleverName
US Northwest
35
09-28-2019 11:27 AM
