DSC Fault code
Attached is the tech manual definition for the code. It is related to the YAW sensor for the DSC System. If you go to the "HOW TO" section you can download the 3rd edition of the tech manual for more info.
https://www.jaguarforums.com/forum/x...ts-data-29800/
Hi, I have a 2005 XK8 "S" which had a DSC fault, when checked it come from the front abs sensors, I bought a number of new ones, but still the fault persisted. Cleaned the plugs did all the fixes, nothing worked. It became an intermittent fault, then a few days ago I tracked it down to the N/S abs sensor, and felt it was a loose connection or the cable, so just pulled the plug off (lifting the locking clip) and rotated it one turn and plugged it back in, so now the wire is under tension, and perhaps I was just lucky, but the fault has gone, so I am pretty sure there is a fault in that cable, but at the moment the fault has gone. So its a simple thing to try, before you spend a load at the Jaguar garage , please give it a try, and fingers crossed.
woox4 (11-02-2017)
